Re: Very Important Rear Suspension Parts.
Mon Apr 23, 2018 11:55 am
by ceejay
Doug
The riser height is 22mm, from top of strut to top of riser.
They also work well for better over all rear susp control and handling.
Mon Apr 23, 2018 5:31 pm
by Davidb
If anyone wants an alternative - I use these from VW/Porsche:
https://www.ebay.com/itm/NEW-Porsche-92 ... Swvg9XU~8fI cut them down by eye and I just measured them after seeing Ceejays dimensions--mine are exactly 78 mm! And work well I can saying after going on a gravel road last year.
I too use 80lb rear springs but from US supplier Qa1--they are guaranteed not to sag-front springs are DBE 115lb.:
https://www.qa1.net/suspension/springs/ ... el-springs
Tue Apr 25, 2023 3:32 pm
by h20hamelan
I had contacted Timbren when this thread was started. They had no part number.
I had experimented with some others, but I still would like to find the Timbren part number.
Hope someone can chime in with dimensions of OEM, or if longer is better ie. without CeeJays alloy spacers?
http://www.thelolaregistry.com/Projects ... ebuild.htm
