For the benefit of our English-only readers, the google translation service is at:
https://translate.google.com/But several of the Internet browser program will translate each page on the go, I'm not sure how that would work on this website though as it is mainly English.
The best way to get a precise Google translation.
Enter the message in the source language box, observe the translated text, REVERSE the translation (by clicking on the two-way arrow icon) and read the translated version again. If that does not correspond to what you want, simplify the source language, delete the idioms, for example. Repeat the process several times until the reverse translated version matches what you wanted to say. Then the translated text will be quite accurate.
Le meilleur moyen d'obtenir une traduction Google pr?cise.
Saisissez le message dans la zone de la langue source, observez le texte traduit, REVERSEZ la traduction (en cliquant sur l'ic?ne des fl?ches ? double sens) et lisez la version traduite ? nouveau. Si cela ne correspond pas ? ce que vous voulez, simplifiez la langue source, supprimez les idiomes, par exemple. R?p?tez l'op?ration plusieurs fois jusqu'? ce que la version traduite invers?e corresponde ? ce que vous vouliez dire. Ensuite, le texte traduit sera assez pr?cis.
