Steering Column Bulkhead Grommit
Posted: Mon Jul 05, 2004 11:28 pm
Hi All,
I'm trying to work out how the steering column should get through the bulkhead in a properly sorted Plus 2S130.
My car had about a 1.25" hole in the fibreglass, with a metal plate with a similar sized hole and a rubber washer on the engine side. This was attached with four screws using plastic rawlplugs drilled into the bulkhead. This plate also had a hole for the speedo cable.
Does this sound right? What should there be?
Are the 'rubber' grommits readily available?
Thanks.
Niall.
Thanks.
Niall.
