Pertol Filler problems
On my +2 the filler cap moves down towards the body when trying to snap it shut and hence the only way to close it properly is to undo the boot and hold the neck up while pressing the cap down. As Yet I have not recieved my manual so can anyone advise if there is supposed to be some form of clamping arangement to stop the filler nech sliding down ?
If do is it special bit ? does anyone have a spare one ?
Peter
[email protected]
Peter
[email protected]
pmallinson - Second Gear
There is no clamp...the cap is held in place by the rubber sealing ring which has a high 'neck' which locates against a flange on the cap mechanism. I guess that you may have the wrong sealing ring or the rubber has rotted?
Peter
From memory,on mine there is a jubilee clip round the neck of the filler and this fixes to the body via a strap? I think?
Hmmm...maybe there's a difference by type of Plus 2. My '74 130 doesn't have any clips or brackets at all, just the rubber seal as above. Of course the filler cap metal 'tube' fits inside the fuel filler hose and that is secured by a clip.
Just checked the Service Parts List (Feb '69) and that doesn't show any brackets either.
Peter,
Don't think the +2 had any clips or brackets. I agree with previous posts - there are no brackets on mine. The filler kneck rests on the rubber seal in the body and the whole thing is anchored by the rubber filler elbow which is attached to both the kneck and the tank by large jubilee clips.
Check all are in good nick and any clips are tight. If you still have a problem, post again.
Hamish.
Hamish.
Hamish Coutts - Fourth Gear
Well thanks for all your advice, it would appear that the rubber is either missing or badly perished then !! I cannot check it because I'm overseas at present but I'm willing to accept that this is the problem.
Next comes the question are they still avaialble ( I have looked though p.Matty parts list and cannot see ?) or does anyone have a serviceable item they would sell me ?
Peter Mallinson
[email protected]
Peter Mallinson
[email protected]
They are in the catalogue...section J 'Grommet, fuel filler neck' about ?8. You had me worried then!
Elanintheforest wrote:They are in the catalogue...section J 'Grommet, fuel filler neck' about ?8. You had me worried then!
Thanks a million I have just ordered 1
Peter
Well you got me going now,so,just been out into the cold and removed the rear of the boot and there is (on mine) a bracket screwed to the sidewall behind the filler tube and a jubilee clip just for the purpose of holding the filler tube.
If it's not original(if anyone gives a toss) it's a good idea....
Which seems to answer the original question.....
Users browsing this forum: smiths everest and 25 guests
