Stuck Clutch
Hi Folks
My Plus 2's clutch seems welded to the flywheel after 3 months of
little use (yes I know how dangerous that is........).
I've had this happen with Triumphs etc and at worst all one needed to
do was start it with a good battery in gear and it would soon release.
I have tried everything I know and am at a loss. Until 3 months ago all
was well.
Any help much appreciated.
Nick
was well.
Nick
- "c1gtc"
There are several options...I usually try them in reverse order of brutality:
First, check that the clutch is properly adjusted and that it is actuating correctly...you may have dodgy seals on master/slave cylinders, for example. Then:
1) With the clutch pedal propped down & gearbox out of gear, start the engine and let it run until **thoroughly** up to temperature. Switch it off, and allow to cool. Repeat this for several cycles.This obviously takes a while, so you'll need patience, but you'd be suprised how often the differential expansion of the clutch and flywheel is enough to break the stuck plate loose, eventually, with no stress to the drivetrain at all.
2) With the car (CAREFULLY) supported on axle stands under the rear hub carriers (not under the chassis or body, as this puts the suspension at full droop, which strains the donuts), start engine in gear, and with clutch pedal depressed, alternately rev and brake. This is obviously using the inertia of the rotating components (mainly the mass of the rear wheels) to break the clutch loose.
3) Most dangerous, and most brutal...start the car in gear and drive it around with the clutch depressed, alternately accelerating and braking. This is doing the same as method 2, but you are obviously accelerating/braking the mass of the car against the clutch..
If none of the above work, I'm afraid it's time to bite the bullet and separate the engine and gearbox.
Don't dismiss option one, though (heat cycling)...it usually works 9 times out of 10 if you have patience!
Martin
----- Original Message -----
To: ***@***.***
Sent: Monday, April 10, 2006 7:24 PM
Subject: [LotusElan.net] Stuck Clutch
Hi Folks
was well.
Nick
a.. Visit your group "lotuselan" on the web.
b.. To unsubscribe from this group, send an email to:
c.. .
Martin
To: ***@***.***
Hi Folks
was well.
Nick
c.. .
- Martin_StuartUK
There are several things that have worked
Go through some heat cycles..starting car.letting warm up.then cool..several
times
I have seen people put the car on a jack..get the wheels a little off the
ground.then start the car.with your foot on the clutch..push the car off the
jack or lower it down. Give yourself lots of room to stop if it does not
break loose.
These are the things that have worked for others
Tony Vaccaro
_____
Of c1gtc
Sent: Monday, April 10, 2006 2:24 PM
To: ***@***.***
Hi Folks
was well.
Nick
_____
* Visit your group "lotuselan
<http://groups.yahoo.com/group/lotuselan> " on the web.
* To unsubscribe from this group, send an email to:
<mailto:***@***.***ect=Unsubscribe>
* the Yahoo!
<http://docs.yahoo.com/info/terms/> Terms of Service.
_____
times
break loose.
Tony Vaccaro
_____
Of c1gtc
To: ***@***.***
Hi Folks
was well.
Nick
_____
* the Yahoo!
_____
Tony Vaccaro
http://www.lotusowners.com
Drive Fast Take Chances
ElanGTS, 93 Caterham, 05 Elise,
99 Elise190, 05 Elise, 2005 MiataSpeed Turbo
tvacc - Coveted Fifth Gear
Thanks Martin & Tony
Method 2 finally worked after 8 attempts.
Why driving it around hadn't previously worked is a mystery, probably
beacsue there wasn't enough time in this perilous method to generate
enough heat.
This group really works, I would never have thought of the advice
to "avoid jacking via chassis to avoid rotoflex strain".
Nick
--- In ***@***.***, "Martin Stuart" <m.a.stuart@...>
clutch..
enough heat.
Nick
clutch..
- "c1gtc"
Martin/Tony/Nick,
While lurking the Lotus mail my 60 MGA developed the same clutch
problem. Your expert methods resolved the clutch problem in 2 attempts.
The MGA had been sitting since 1975. 31 years!!!!!
thanks,
Ty
Tiger, Healey, Morgan, Lotus, 2 MGA's
________________________________
Sent: Tuesday, April 11, 2006 8:27 AM
To: ***@***.***
Subject: Re: [LotusElan.net] Stuck Clutch
enough heat.
Nick
clutch..
SPONSORED LINKS
Plus
<http://groups.yahoo.com/gads?t=ms&k=Plus&w1=Plus&w2=Sprint&w3=Devoted&w
4=Enjoy&w5=Impressions&c=5&s=63&.sig=dIq6370auMI5unlj264rKg> Sprint
<http://groups.yahoo.com/gads?t=ms&k=Sprint&w1=Plus&w2=Sprint&w3=Devoted
&w4=Enjoy&w5=Impressions&c=5&s=63&.sig=muI6crmvtqUoTgRYka59Rg>
Devoted
<http://groups.yahoo.com/gads?t=ms&k=Devoted&w1=Plus&w2=Sprint&w3=Devote
d&w4=Enjoy&w5=Impressions&c=5&s=63&.sig=MYr8YVWitcFnMagQQ6nJVA>
Enjoy
<http://groups.yahoo.com/gads?t=ms&k=Enjoy&w1=Plus&w2=Sprint&w3=Devoted&
w4=Enjoy&w5=Impressions&c=5&s=63&.sig=zUhOBysTd0f_oe18NDhODg>
Impressions
<http://groups.yahoo.com/gads?t=ms&k=Impressions&w1=Plus&w2=Sprint&w3=De
voted&w4=Enjoy&w5=Impressions&c=5&s=63&.sig=fS0z9y1WMhoC-cy_ETCXnA>
* the Yahoo! Terms of
Service
thanks,
Ty
To: ***@***.***
enough heat.
Nick
clutch..
SPONSORED LINKS
Plus
Devoted
Enjoy
Impressions
Service
- rodgerslotus
Whenever laying up a 30 - 40 year old car for even a month, it seems to be a good idea to prop the clutch out to prevent it from sticking. If it's mechanical or cable, you can do this by propping out the pedal, but for a hydraulic clutch, the prop needs to be at the release lever. Some people say that this will weaken the clutch springs, but I have never had this problem.
Ken
NW Florida
'69 Plus 2, etc
How low will we go? Check out Yahoo! Messenger?s low PC-to-Phone call rates.
Ken
NW Florida
'69 Plus 2, etc
- kayenney
I have been reading the thread on stuck clutches for the last week or so
with interest, as I had a stuck clutch on my 66 S3. I tried warming up
the engine and letting the engine cool with the clutch pedal depressed -
and it was fixed after one cycle. So thanks for the suggestion and it
turned out to be much simpler than I expected.
66 S3 DHC
66 S3 DHC
66 S3 DHC
66 S3 DHC
- john66s3
